Believe I have a bad wheel bearing.  Quiet grinding noise that changes with speed and is not affected by braking (also changed brakes so know they are not the issue).  I have a 30mm and a 32mm socket (both 6-point) but neither will fit over the spindle/axle nut.  The spindle/axle nut is a 12-point nut if that matters.
Does anyone know what size socket I need to buy?  TIA
Lexus Owners Club
This post was recognized by Lexus Owners Club!
NewEnglandLexus was awarded the badge 'Great Content' and 25 points.
Got the job done!  It required a 12-point, 30mm socket. Took less than an hour.  I wrote a detailed step by step process with some pictures, helpful youtube videos and links to parts RX350 hub bearing replacement.docx
  • Like 1
  • 4 months later...
Thanks for the procedure!👍
