Any tips on replacing speed wheel sensor/s on my ES330/2004?
dommm
16 minutes ago, dcfish said:
Straight forward job, One bolt to remove the sensor from the wheel hub, Follow the wire back to connector, Disconnect and reverse the procedure to install.
Thanks for your reply dcfish. Are all 4 sensors identical? I have been googling the issue & am having trouble finding my exact model (2004 Lexus ES330). It seems on some models the front & back sensors are very different looking.  Thanks
14 minutes ago, dcfish said:
The wiring may be of different lengths. They may be the same sensors on a Toyota Camry of the same years  😉
Here is what I am referring to when I say they look different. Thanks
15 minutes ago, dcfish said:
If you are having questions and want facts, Call a Lexus Parts department and verify the parts you need and there part numbers and cost. Then you can research for a better price.
Gotcha, Thanks
