bob2lexus Posted October 25, 2021 Posted October 25, 2021 1998 ls 400, barn find 100,000 miles cranks but will not even kick last driven 2013
bob2lexus Posted October 25, 2021 Author Posted October 25, 2021 put new gas in tank took line apart in engine bay zero gas in line and none while cranking over
Bykfixer Posted October 26, 2021 Posted October 26, 2021 Many say turn the key to start it and you can hear the pump begin to hum. In this case remove the horizontal part of the backseat to hear it a lot better. If it is the pump you've already done a fair amount of the work to replace it as it's located under the back seat driver side.
Jeremy M. Posted November 5, 2021 Posted November 5, 2021 (edited) You might try blowing compressed air through the line, in from the hose leading out the fuel pump (assuming the fuel pump is working) and letting any gunk clear from the other end. Another thing to check, although I'm not 100% on this, is whether the key is programmed to the car properly. I know that the key, even if it will turn in the lock and crank the car, won't ever start it without being programmed properly as a security freature, but I'm not sure if it disables the fuel system or the spark without the programming. Edited November 5, 2021 by Jeremy M.
