LennyF Posted July 3, 2021 Posted July 3, 2021 Suddenly the tire pressure indicator on my instrument panel stop showing numbers, only dotted lines. (All four positions) I tried pressing the reset button under the dashboard, was no help I contacted Lexus on call Tech-Support but they were of no help. Anyone have any ideas?
Lexigrl Posted December 29, 2021 Posted December 29, 2021 Mine is intermittent. Interested to find out what is happening too.
RX400h Posted December 29, 2021 Posted December 29, 2021 I believe those sensors need to be replaced every so many years but make sure you first closely follow the owner's manual's instructions to reset.
Lexigrl Posted December 29, 2021 Posted December 29, 2021 (edited) What's strange is that it's not popping up the tpms warning icon on the dashboard. I just noticed the psi wasn't displaying when scrolling thru and got to the tpms. And then on a different occasion it did read the pressure. I'll have to get the sensors checked out tomorrow with my Autel Edited December 29, 2021 by Lexigrl
Bykfixer Posted December 29, 2021 Posted December 29, 2021 https://rxmechanic.com/how-to-program-tpms-sensors/ This may help
LennyF Posted December 29, 2021 Author Posted December 29, 2021 16 hours ago, RX400h said: I believe those sensors need to be replaced every so many years but make sure you first closely follow the owner's manual's instructions to reset. no doubt the tire pressure sensors go bad and have to replace eventually, but I doubt they all go bad at the very same time as in my case.
LennyF Posted December 29, 2021 Author Posted December 29, 2021 4 hours ago, Bykfixer said: https://rxmechanic.com/how-to-program-tpms-sensors/ This may help Tire pressure sensors are fine, they have all been checked individually
Lexigrl Posted December 30, 2021 Posted December 30, 2021 I would like for the psi to display, but decided this is a rabbit hole I don't want to go into.
LennyF Posted December 30, 2021 Author Posted December 30, 2021 2 hours ago, Lexigrl said: I would like for the psi to display, but decided this is a rabbit hole I don't want to go into. I don't blame you at all for feeling that way. The "fix" is to replace the main tire pressure control module, which is pricey and undoubtedly expensive labor.
Lexigrl Posted December 30, 2021 Posted December 30, 2021 First the signal from the sensors goes to the "Receiver Assembly, Door Control & Tire Pressure Monitoring System" ($310) which is buried behind the rear pillar somewhere, and then from there the info goes into even more expensive parts/pieces. And even if the problem is only with the $310 box; you have to tear apart the whole back of the car just to get to it. Nah...I'll check my pressures with my trusty gauge the way we used to do it before the gov't go involved & legislated the stupid systems.
LennyF Posted December 31, 2021 Author Posted December 31, 2021 5 hours ago, Lexigrl said: First the signal from the sensors goes to the "Receiver Assembly, Door Control & Tire Pressure Monitoring System" ($310) which is buried behind the rear pillar somewhere, and then from there the info goes into even more expensive parts/pieces. And even if the problem is only with the $310 box; you have to tear apart the whole back of the car just to get to it. Nah...I'll check my pressures with my trusty gauge the way we used to do it before the gov't go involved & legislated the stupid systems. I'm not 100% sure on this, but I believe that once you replace the $310 control box, you need to have it programmed to be compatible with the car's ECU. Anyone have more info about this?
Lexigrl Posted December 31, 2021 Posted December 31, 2021 9 hours ago, LennyF said: I'm not 100% sure on this, but I believe that once you replace the $310 control box, you need to have it programmed to be compatible with the car's ECU. Anyone have more info about this? I wouldn't doubt it since the door control is also part of the module. That's why I'm just leaving it alone. the light is not coming on the dashboard. out of sight out of mind.😐
Lexigrl Posted January 7, 2022 Posted January 7, 2022 Well....I had no idea how old the tpms sensors that were in car when I got it last week. So while I was getting new tires I had discount tire install new sensors while they were doing the tires anyway, (bought a set of factory Denso's from Amazon). They were able to learn the sensors, and all is well now and display the pressures. Glad I don't have to dig into the tpms system any further.
LennyF Posted January 8, 2022 Author Posted January 8, 2022 Very good, I'm happy that you had a favorable solution. I was not so lucky
Lexigrl Posted January 8, 2022 Posted January 8, 2022 The strange thing is that I was able to trigger the old sensors with my Autel TPMS tool. Reading pressure, battery was ok, and the ID's matched what my other scan tool was showing, but they were probably original and 8 yrs. old. But the car was reading all sorts of strange values in live data. I figured that couldn't properly diagnose if the sensors where questionable due to age. We had the whole back of the car tore down to start with the receiver box once the sensors were known new and good. I saw some videos where others have replaced that receiver box and that worked for them. So spent last night putting the interior back together. Hope you can get yours sorted out.
