HI All,
So i happen to have another LS 460L 2007 model but American Specs with ODO sitting at 200k miles which my brother drives
Its an old issue and now fixed but i feel i should share here on this platform also so that other users can take some help if any
Event Date 25-Mar-21
During driving all of a sudden battery symbol appeared along with all the other lights on the dash and lost power steering, brakes became hard as manual with no hydraulics etc, so brother drove it for like less than a mile and parked the car in the house.
Replaced the battery, car was firing right away but battery symbol did not go away and message was coming "Check electrical generator"
1406405767_WhatsAppImage2021-05-26at4_39_56PM.thumb.jpeg.59c8e8eabb6d103f7fb08fa075ccbb4f.jpeg
Update on 4-Apr-21
Called the recovery truck and sent the car to a garage nearby
Picked up the following scan codes with Launch X431 series
965628713_LS460-2007-OBDcodes-4.thumb.jpeg.bdcca668b663f84b1a3970b9b4de64ab.jpeg164904552_LS460-2007-OBDcodes-3.thumb.jpeg.47303ceb127d85e807e4219814e2ba9a.jpeg1370777740_LS460-2007-OBDcodes-2.thumb.jpeg.28fa3a53010740eb38d69dbcc3ec17da.jpeg896231917_LS460-2007-OBDcodes.thumb.jpeg.320b29ce17d7ec10cb0a78a6e9e37a81.jpeg
Replaced the Alternator and some kind of re-calibration and the battery light went away
Further diagnostics proved that the ABS system have unfortunately failed
So it appears to be and assumption points to that the car was driven initially in that condition earlier caused everything else to fail, not sure weather thats true or not
Update 4-May-21
Replaced the ABS system with a used one from Scrap yard
Replaced Fuse Box with a used one from Scrap yard
and codes went away
362463947_WhatsAppImage2021-04-26at10_45_03AM.thumb.jpeg.b6d47ad6fbc4f5706fdebd806d489948.jpeg
Took the car and upon climbing a bridge CEL came on again
Sent the car back to garage again on 5-May-21
Pulled up codes again
970124236_LS460-2007-OBDcodes-4-May-21-6.thumb.jpeg.09470f9eb7a7a2bded0b480cfbf8d5db.jpeg34629882_LS460-2007-OBDcodes-4-May-21-5.thumb.jpeg.92ab507cc27d8583ed441de8d4e76fd9.jpeg1674528148_LS460-2007-OBDcodes-4-May-21-4.thumb.jpeg.f81c38a019475510372f14a0e957f970.jpeg1299482262_LS460-2007-OBDcodes-4-May-21-3.thumb.jpeg.2e0a34a246d66847f73fa71953bdd335.jpeg1544539235_LS460-2007-OBDcodes-4-May-21-2.thumb.jpeg.c7874f3ea9758ebd75ad6a7c9d5fbc6f.jpeg1369349764_LS460-2007-OBDcodes-4-May-21.thumb.jpeg.af3fd2e15ceb16a9f31cb2ef1a44eae5.jpeg
Appears to be O2 sensors, so replaced both O2 sensors bank 1- before the CATS
Did a reset from the scan tool and test drove, again the CEL came on with the same codes as above
After brainstorming from the garage, the car was sent to another shop who appears to have an active subscription over TIS and re-flashed the ECM (not sure exactly what was done in details) and cleaned the Catalytic converter
That finally solved the problem
Took the car finally on 24-May-21 and now working ok, spent big money but worth it and air ride changes the game comparing with what i have with coil springs
1022211531_WhatsAppImage2021-05-26at4_39.12PM(1).thumb.jpeg.71274a5ca9c4a47684298809b405df6b.jpeg178191350_WhatsAppImage2021-05-26at4_39_12PM.thumb.jpeg.5e86162f1b19eacee9920f22965bec58.jpeg
Any feedback with what i could have done differently would be appreciated
Thanks
Wow!  that's some journey to get to the end result and sometimes there are no shortcuts.
looking at all the fault codes, it does seem there was quite a bit to resolve so not sure you could have done much differently.
Well done on spending the time and money on rescuing the old girl, you've now got a superb Lexus as a result
Hi Trevor
That's a very positive response i have to say it!
The problem was when we initially purchased the car all the lights except the ABS were coming up so we negotiated the price of the car knowing in a way that it would require maintenance but what we didn't accounted for that expertise on these are cars is not easy to find, it needs a skilled mechanic with experience to understand the root cause of the fault codes and not just replace what the computer is trying to say
Still i have a VGRS code which is not letting the whole display work, any leads what would be the probable cause and how to fix it would be appreciated
But yes in the end its every penny worth it!
Some pics
1849380739_WhatsAppImage2021-05-29at7_53_00AM.thumb.jpeg.552b24224a1660b9eb9ff42f7890d4d6.jpeg1386235464_WhatsAppImage2021-05-29at7_53.00AM(2).thumb.jpeg.2209330bb4e4c32a0cca1a2506f51335.jpeg717244518_WhatsAppImage2021-05-29at7_53.00AM(1).thumb.jpeg.c635b9d8893b6624437593186d689706.jpeg
