Can anyone help me with some information on how to get my factory rotors off so I can replace them with the Brembo drilled and slotted rotors ? I have tried twice now and am not sure why they are not coming off. thanks for any help.
There are also bolt holes on the stock rotor hub. I can't remember what size these are but if you put the bolts in, as you tighten, it will put pressure on the hub (since the bolt is geting longer on the other side) and pop out the rotor.
