JDOwen2 Posted May 5, 2004 Share Posted May 5, 2004 I just installed Sylvania Silverstar H3 bulbs in my fog lights. The underside splash shields on both sides had to come off. There are two 10MM nuts holding the fog lights in place as well as an 8MM bolt that installs from the top. The driver's side is a little more difficult because of A/C plumbing but it's not bad. I removed the light housings to gain access to the bulbs. It seemed easier that way. Swapped out the bulbs and reinstalled housings. Maybe 45 minutes. There is also an adjustment screw that I cranked up about 1 1/2 turns. The test will be tonite, I have to be at work at 3 A.M. I'll repost with the results tomorrow. Quote Link to comment Share on other sites More sharing options...
Calvin L Posted May 5, 2004 Share Posted May 5, 2004 hope you take some pictures. :D Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted May 5, 2004 Author Share Posted May 5, 2004 Fog lights are definately whiter/brighter. I wish they were driving lights instead. I'm not sure a picture would show anything. Quote Link to comment Share on other sites More sharing options...
SPORTcoupe300 Posted May 5, 2004 Share Posted May 5, 2004 If you're up to it and you know electrical, you can make them into driving lights pretty easily. Quote Link to comment Share on other sites More sharing options...
