Powade Posted July 25, 2019 Share Posted July 25, 2019 My only key fob to my 1999 sc400 was stolen. Lexus dealer tells me that Lexus no longer sells keys for that year. I assume I can get a locksmith to get into the locked car. Any suggestions as to how I can start the car without the key? Quote Link to comment Share on other sites More sharing options...
Paul Cook Posted July 26, 2019 Share Posted July 26, 2019 Houston, you have a HUGE problem. When you say key fob, I am assuming you mean the key as well as the remote that locks and unlocks the vehicle. Do you have the Valet key that came with the car or the small rectangular silver aluminum key code that should be in the owners manual booklet? Because if not, you have a very large planter unless you want to spend a considerable sum to get all of the various electronics to talk to each other. The dealer MAY be able to help with the key code and even the transponder if they decide to be helpful. You can get replacement keys on ebay. Even get them cut for not much money by using just a picture of the key. Im sorry that I doubt you have a good picture of your original key and remote. 1. You need a key cut. Without a master, that's basically impossible. 2. You need the proper frequency transponder to talk to the car. 3. You need the key coded to the ECU and its imobilizer circuit. Option one. Seek out a professional automotive lock smith for their opinion on what your real options are. Two. Get used keys, locks, ignition and doors and the matching ECU from a salvage car and HOPE it works when your done installing everything. Im sorry. I hope I'm wrong and someone else chimes in with a simple solution because I know I am giving you absolutely doom and gloom. But keys in modern cars are way more complex than a simple house key. So sorry for your loss. Paul Quote Link to comment Share on other sites More sharing options...
DanieMartinez Posted December 20, 2019 Share Posted December 20, 2019 it's not easy to do key cut but still i will give a try and if it won't work i will contact a locksmith. Quote Link to comment Share on other sites More sharing options...
GabrielBaldwin Posted June 12, 2020 Share Posted June 12, 2020 If the door locks are not working and its the linkage problem then its better to hire an emergency locksmith to help you in that crisis. Quote Link to comment Share on other sites More sharing options...
