Telluridescott Posted July 24, 2019 Share Posted July 24, 2019 Now I know this might sound crazy but my Lexus LX 470 will start and run just fine. You can shut it off fill it full of gas and it will start right back up. If you shut it off and wait 45 minutes it will not restart it just cranks. If you let it sit for three or four hours it will start right up. Any ideas? I’ve had the starter replaced and that did not fix the problem. Quote Link to comment Share on other sites More sharing options...
Paul Cook Posted July 25, 2019 Share Posted July 25, 2019 Do you have a diagnostic scanner to check for DTC codes? Could it be your gas cap? The only wild guess I can dream up right now is some kind of a vacuum problem or vapor lock situation. Im assuming here that this only happens after the engine is at normal operating temperature. Paul Quote Link to comment Share on other sites More sharing options...
eugene.s Posted July 28, 2019 Share Posted July 28, 2019 Might be worth checking the battery. This happened to me before with a depleted battery. I used it for ~5 years, a few times it drained beyond "recharge" but I still managed to manually charge it to full. While on engine running, it went up up to ~13.3-13.5V (as due), when i left the car idle for a day or two, it went down to ~12.3V (lower than due). Sometimes i was unable to start from the first attempt; sometime had cranking first but waiting for a few minutes, it somehow readjusted and started (but not always). Quote Link to comment Share on other sites More sharing options...
LilaLexus Posted December 30, 2023 Share Posted December 30, 2023 I have a 2003 Lexus LX470 - I have a s starting issue which no one has been able to diagnose - not even Lexus mechanics. It’s a mystery - not the battery, not the key, not the starter. This is an intermittent issue. Once car is on it never turns off. When I turn the key it makes the sound of almost turning on but it doesn’t. It has nothing to do with the cranking it just has to do with that initial sound a car makes before the engine turns on. I’ve gone 3 months without an issue then out of the blue, it doesn’t start. I wait a couple of minutes, hours nothing. mechanics have not been able to replicate the issue. I’ve sent videos and still nothing. Anyone ever experienced this? Appreciate any insight. Quote Link to comment Share on other sites More sharing options...
