I've got a 00 RX300. The light on the AC button flashes and intermittent cold. So I figured it was the relay. Inserting a paper clip, I know it's a no-no, keeps the air blowing. So I moved another of the exact same relays over to the AC slot (see picture #1). Still no air. So it doesn't appear that another relay fixes it. But why would the paperclip get it running? The problem with the clip is that it quits after an hour and won't blow cold again for an hour or so.
No matter what combination of relay moving between 1,2, and 3. The air will not blow cold without a paper clip.
Any ideas?
Pic layout..
1) is the AC
2) ?
3) is fuel pump
This topic post should answer your questions
Cheers  Trevor
