Lexus562 Posted April 23, 2016 Posted April 23, 2016 I took it to the mechanic and he changed out all my struts when I took it back home ABS light turned on. Took it to Toyota they said at all my speed sensors were fine but it might be my module I got a used but working module still didn't work any hints or answers ?
gbhrps Posted April 24, 2016 Posted April 24, 2016 Lexus562, Your problem may have been fixed, but unless the DTC (diagnostic trouble codes) are erased and the system reset, the codes may still be there, and its possible that the ABS and Trac lights will still be on. Try disconnecting the battery for 2 minutes or so to reset the computer, and then restart the car and see what you have. If that doesn't do the trick, there may be another issue that needs addressing by a good mechanic, not necessarily a Lexus one. Good Luck!
Lexus562 Posted April 24, 2016 Author Posted April 24, 2016 I tried that but still flashing. Also changed ABS Sol and ABS motor fuses. Still the same. Going next month to do an ABS diagnostic. We'll see how that goes.
