cltractor Posted December 16, 2015 Posted December 16, 2015 The lights are out on the adjustment buttons for the rear view mirrors. Is this a blown out fuse? Thanks in advance for any and all responses!!!!
eugene.s Posted December 19, 2015 Posted December 19, 2015 Hi, I am being confused. Please describe your issue precisely if you want to receive any support at this forum
1990LS400 Posted December 19, 2015 Posted December 19, 2015 If this is about the adjustment switch and fold/unfold button for the exterior mirrors, the backlight bulb is probably burned out - see the attached diagram for the part number.
hankinid Posted December 20, 2015 Posted December 20, 2015 The lights are out on the adjustment buttons for the rear view mirrors. Is this a blown out fuse? Thanks in advance for any and all responses!!!! If none of the other illumination bulbs are out, your issue is a probably a fuse...it could also be a defective switch, but a bulb is FAR more likely. Hi, I am being confused. Please describe your issue precisely if you want to receive any support at this forum "lights on the adjustment buttons for the rear view mirrors"... A little switch...driver's side...lower portion of the dash. You press the buttons and the mirror things on the outside of the front doors move in and out and up and down...
