softeject70 Posted November 6, 2015 Posted November 6, 2015 Greetings all: We've been experiencing a strange problem with our dashboard clock over the past several months, and no matter how we try to fix it, the problem persists: The clock somehow tends to "speed up" or "run fast," ending up reading a time that is more or less 45 minutes in advance (i.e., if it's 9PM, it'll state 9:45PM). I know this is ripe for some Back to the Future jokes, but it's been really annoying. We've given up trying to fix it, so normally we just subtract about 45 mins. from the readout. What I don't understand is how it gets to that point. I don't have time to actually guage how fast the clock is running, but we'd set it and notice that within a few days, it would already be off by more than a couple of minutes and continue to do so until it reaches about 45 minutes ahead, then it stops and settles. Does anyone else have this problem? How is it that such a basic electronic mechanism as a dash clock be out of sync like that?? Thanks for your time.
ou812 Posted November 6, 2015 Posted November 6, 2015 my car is doing the same its been like that about 2 months now, it is very annoying, I would said its abou 45 minutes faster
maseace Posted November 8, 2015 Posted November 8, 2015 Maybe the battery is getting low causing the clock to not keep it setting?
katzjamr Posted November 9, 2015 Posted November 9, 2015 Mine has done the same thing since almost day one in 2005, I have a great dealer but for some reason I waited a year to complain about it and they said the only solution is to replace the entire center stack, they cannot replace the clock only. I was told they would do that in the first twelve months of ownership only at lexus expense and it would be my responsibility after that. This dealer has helped me with other things and as I said been honest and reliable so I just decided to live with it, but it does look like it is a more common problem than what I was led to believe.
Carmichaels0120 Posted December 21, 2019 Posted December 21, 2019 Wow, The clock in my 2015 IS250 is a runaway,it never settles down now running approximately 12 hours ahead. I see my life passing before me in warp speed!
RX400h Posted December 24, 2019 Posted December 24, 2019 No problems with the clock in the 14.5years we've had our RX400h
Duke22 Posted May 22, 2021 Posted May 22, 2021 Same problem with my 2013 Lexus Gs350 with the clock consistently running fast. I ended up replacing the crystal on the clock circuit board and problem fixed. Cost me a total of 33 cents....
lexo13 Posted June 23, 2021 Posted June 23, 2021 On 5/21/2021 at 9:27 PM, Duke22 said: Same problem with my 2013 Lexus Gs350 with the clock consistently running fast. I ended up replacing the crystal on the clock circuit board and problem fixed. Cost me a total of 33 cents.... On 5/21/2021 at 9:27 PM, Duke22 said: Same problem with my 2013 Lexus Gs350 with the clock consistently running fast. I ended up replacing the crystal on the clock circuit board and problem fixed. Cost me a total of 33 cents.... Do you mind giving more details on this? I have a 2013 Gs with the same issue.
Greggans Posted September 28, 2021 Posted September 28, 2021 Duke22: Can you please reply back with the crystal part number? I am an electronic engineer and always welcome the opportunity to use my abilities to save $$$ on car parts by doing a repair myself. 🙂. My 2013 GS350 F-sport clock has just this month started running fast. Thanks in advance...
Greggans Posted October 25, 2021 Posted October 25, 2021 lexo13: Did you ever get more details on the clock crystal? Thanks. Duke22: One more attempt to find out more. Please reply back if you are able. Thank you.
Stephen Melchert Posted November 28, 2021 Posted November 28, 2021 Same problem. Would love to know the solution!
sturothman Posted June 15, 2022 Posted June 15, 2022 Anyone find out how to replace the crystal on the circuit board to correct my analog clock on my 2014 GS350 ? Thanks for your help , Stu
Mike Reilly Posted October 10 Posted October 10 I have 2017 es 350 , the speeding dashboard clock just started.... I went to Lexus they wanted $1044.00 to fix!!!
