2006 Lx 470 90,000 Mile Service Done
Alldrums
Maintenance schedule notes timing belt should be replaced every 90K...Since the water pump needs to be removed to get to the timing belt, and since the water pump is cheap, it should also be done with the belt as a matter of course.
If you need the maintenance schedule, you should be able to find on on lexus.com...check the resources there for the schedule.
hth
Steve
