tz2000ls400 Posted June 1, 2015 Share Posted June 1, 2015 I have a 2000 ls400. Where is the factory amp located? I have the pioneer premium sound. Also what's the best way to install an aftermarket radio? I have the dash kit. I know an adapter wiring harness is not made. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted June 1, 2015 Share Posted June 1, 2015 Amp is under the front passenger seat. Several companies make adapter harnesses with the one from Beatsonic generally regarded as the best due to it working with the subwoofer. Quote Link to comment Share on other sites More sharing options...
tz2000ls400 Posted June 1, 2015 Author Share Posted June 1, 2015 Thank u Quote Link to comment Share on other sites More sharing options...
tz2000ls400 Posted June 2, 2015 Author Share Posted June 2, 2015 I don't see the amp under the seat. Does the seat have to be removed and carpet pulled back? It seems much easier to hard wire it then spend $300 on a harness Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted June 2, 2015 Share Posted June 2, 2015 Remove the plastic vent cover to expose the back of the amp where all the connectors plug into it. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted June 2, 2015 Share Posted June 2, 2015 You have to remove the vent cover to expose the amp. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted June 3, 2015 Share Posted June 3, 2015 Of course the cheapest way is to put your headphones in and abandon the factory stereo. Terrible but I do despite an incredible sound system. I will admit that I care more about the music than the sound. Beside, factory nav is wicked annoying and the headphones eliminate that. If you are a audio type, find a local shop. For under a grand they'll hook you up. I guess because of headphones car stereo prices have plumentented. Bluetooth, wifi.. yeah they have it all but headphones are better for me because my music stays on in Home Depot, Target, Food Lion wherever. Quote Link to comment Share on other sites More sharing options...
Exhaustgases Posted June 8, 2015 Share Posted June 8, 2015 Absolutely no one ever wants to deal with someones UNPROFESSIONAL hard wire job, unless the car is destined for a junk yard when your ready to get rid of it. Do it right! If you don't want to pay 300 for the correct jumper wire, then make your own. Just don't cut out the original plugs, those clamp on wire T's just mess up the wire and some times develop a bad connection. But are better than cutting off the connector. Quote Link to comment Share on other sites More sharing options...
