Lexus Sc300 Ac Unit
Actually, it never leaked, at least as far as I know. I was driving down the street when it simply would not start, no air, no indication that it even has air. When I press the button for the A/C control, it does nothing whatsoever. It almost appears to have been disconnected or shorted out or something. If it's a fuse, I'm not sure where or what to check, because there seems to be no fuse for the A/C. please help!! :)
Just as question, did you turn the fan on first before pushing the A/C button? Since you said no air at all, your A/C will not come on without a fan running. If your fan doesn’t come on, check for blown fuse, and if fan works and don’t hear the A/C clutch engage, check your A/C relay. If A/C clutch engages but no cold air, good chance you have no/low gas. I think up to ’94 used the older type, which will require gas exchange ($150-200). A/C is a simple unit so if one is not familiar with the system, takes it to any reputable shop.
Had the same problem.
My first question is does anything work? Heat etc? No power whatsoever?
If so, then it was the same problem I had. Check the cigarette lighter for a coin inside. It's a blown fuse.
If not the case please disregard all I said and it's a new wrinkle in the brain.
Thank you all! I think it's the cigarette lighter. I dropped a magnetic pen in the lighter reservior by accident and it didn't work after that. Do I just replace the fuse for the cigarette lighter from the fuse box under the hood?
