Vegan Posted August 19, 2014 Share Posted August 19, 2014 Engine died while driving and wouldn't start again. Found crankshaft pos sensor had fallen off. It connects to a place near the underside of the oil pump pulley, and I could find nothing online of where it's located. Quote Link to comment Share on other sites More sharing options...
billydpowell Posted August 19, 2014 Share Posted August 19, 2014 this should help,item # 15100r on scan... seems like you could just get under it and see where it goes.. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted August 20, 2014 Share Posted August 20, 2014 here you go. Quote Link to comment Share on other sites More sharing options...
Vegan Posted August 24, 2014 Author Share Posted August 24, 2014 I replaced the sensor and cleaned the connector, but still has code 12- RPM signal no.1 and won't start. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted August 24, 2014 Share Posted August 24, 2014 Are you sure the sensor is good? Quote Link to comment Share on other sites More sharing options...
Vegan Posted August 26, 2014 Author Share Posted August 26, 2014 No, everything was fine until old one fell off. Got it running now, but seems to be missing a clyinder and has the same code. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted August 26, 2014 Share Posted August 26, 2014 Check this out. http://www.clublexus.com/forums/gs-first-generation/725746-code-dtc-12-cel-on-rpm-signal-help-please.html But you more than like might need a new sensor. Quote Link to comment Share on other sites More sharing options...
