Zdeno Posted March 31, 2004 Share Posted March 31, 2004 Like everybody knows :D I have new A/C. Want to ask about bad smell from vent when I turn on the A/C. It´smell like a .... nothing compare to And other question is - Is normal that the rear window gets foggy a lot ?? Quote Link to comment Share on other sites More sharing options...
wwest Posted March 31, 2004 Share Posted March 31, 2004 Smells like... old dirty gym socks....?? goto airsept.com/eed.html Quote Link to comment Share on other sites More sharing options...
RCRFAN3 Posted March 31, 2004 Share Posted March 31, 2004 It sound like it could be a dirty cabin filter. Check it out ,It made a huge diffrence on my 98 LS. Quote Link to comment Share on other sites More sharing options...
VMF Posted March 31, 2004 Share Posted March 31, 2004 it smells like you got a LEAK!!!! go back ot the store and give em hell!!!! they should put special freon with die into the system and then after you use it for a day, leaks will be visible with blacklight. Quote Link to comment Share on other sites More sharing options...
darkness Posted April 1, 2004 Share Posted April 1, 2004 If you have a "wet dog" smell pull out the air filter to see if it improves. Also try keeping the A/C vent control on the fresh air recirculate to keep mostier from building in the system. The A/C system itself is a closed circuit system and cannot become contaminated. If leeking will only lose freon but is a high pressure source not allowing contamintes to come in. Quote Link to comment Share on other sites More sharing options...
VMF Posted April 1, 2004 Share Posted April 1, 2004 can you please use regular fonts and colors? the colors and font size that you use are innapropriate and just get out of a regular club style. thank you for understanding. Quote Link to comment Share on other sites More sharing options...
austinls Posted April 1, 2004 Share Posted April 1, 2004 Once I realized my 1994 had a cabin filter, I changed it and my musty smell issue went away. The filter was "caked" with crud...a good $50 investment and easy to change (thanks to instructions from members of this site) Quote Link to comment Share on other sites More sharing options...
admobis Posted April 24, 2004 Share Posted April 24, 2004 I have the same problem w/ my '94 LS A/C. Zdeno, were you able to fix it? autinls mentioned that once he (I'm assuming) replaced the "cabin filter" the bad smell issue went away. Thanks for your reply. Quote Link to comment Share on other sites More sharing options...
