Hi There...
Since I make plenty of mistakes, maybe the dealership did too, but should I pay for it?
Here's my situation~ I took my car in for 02 sensor knowing I was previously quoted $360.00 for removal and replacement at a private shop. The Lexus Dealership advertises 'price matching' so I took it there...
They called and said that not one, but two sensors were recommended at a cost of over $1,040.00 to do so. I said if the second was not failing, just 'lazy' as they put it, that I would hold off... just replace the one.
They called back a while later and said that the exhaust manifold cracked or busted due to an old rusted sensor (car has 151K and I'm original owner) and that I would need to replace that as well for a cost to me of approximately $700.00!
This seems like a lot to me...
I believe it is the rear sensor since the front under the drivers seat would not touch the exhaust manifold. The check engine light has been on and off for a couple years tho I don't drive this car more than 6K per year as it is one of two that I drive. Additionally, the other mechanic has been well aware of issue and said if I couldn't afford it, that waiting would not hurt anything.
Please help if you know something~
I'm supposed to pick the car up today and I don't want to get rocked.
Wow Lynda, that sucks. I don't know what to tell you. I would at least ask them if they would do it at cost.
When my car runs out of warrantee, I'm either going to take it to Toyota or find me a good shop. Dealerships are better known as stealerships.
I would decline the service, go to an independent. The manifold could be welded....Or get a used one from a junk yard.
