kerrycoffman Posted May 26, 2014 Share Posted May 26, 2014 I am trying to install a Garmin Backup camera, and I need to know how to remove the trunk lid insulation on my 03 LS430. I have attached a picture of the fastener. Quote Link to comment Share on other sites More sharing options...
13IS250C Posted May 27, 2014 Share Posted May 27, 2014 Gosh, I haven't a clue. Sorry. Good luck and welcome to LOC. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted May 27, 2014 Share Posted May 27, 2014 Show your photo to someone behind the counter at an auto parts store and he will show you applicable tools. Mine is like a screwdriver with a flat Y-shaped tip that can slipped under the heads of these and similar friction fasteners to pry them out. Quote Link to comment Share on other sites More sharing options...
tophog Posted June 23, 2014 Share Posted June 23, 2014 I just removed about 8 of those this AM to remove my faulty ML amplifier. I just used a small flathead screw driver that fit thru the slot and pried them out. It helps to pry up under the base with a larger flat head screw driver simultaneously. I'm sure the right tool would work better but I managed. Quote Link to comment Share on other sites More sharing options...
