johnfitzgeald Posted March 18, 2004 Posted March 18, 2004 both the left and right door panels (the plastic housing on the power window,lock and mirror switches) on my 95 lexus es300 have cracked. Is this a common problem? Can these be easily taken out and swapped with good ones from a salvage yard? does the door panel have to be taken out?
SKperformance Posted March 19, 2004 Posted March 19, 2004 That whole plastic panel nees to be replaced and the door panel has to come off.
Latoilette Posted March 19, 2004 Posted March 19, 2004 i second that. you have to take the door panel off. there are two screws and 1 plastic clip underneath the window control thingy.
chabig Posted June 1, 2004 Posted June 1, 2004 I see one screw at the front. Where is the other screw? Chris
66zoomie Posted June 8, 2004 Posted June 8, 2004 FWIW, three (3) of these plastic assemblies have cracked on my 94 ES300, all at the same point: the forward ~2" of the assembly. Original and replacement assembly cracked on the driver side door, the original on the passenger door. The replacement assembly was something like $85-$90 about four years ago...which explains why my vehicle has two cracked assemblies that have NOT been replaced (again!)
SKperformance Posted June 8, 2004 Posted June 8, 2004 they crack when they are misaligned when the door panel is reinstalled
