I have a 98 GS 400 and my check engine, vsc and vsc off lamps are all on. When the lights first came on, the engine had a rough idle while at a red light. I turned the car off and on and it drove fine, 2 days later the codes cleared. While driving again...the codes reappeared...my car was a bit sluggish but it had no problem doing freeway speeds and driving around town.
I finally took the car to the Lexus dealer and they pulled codes P0715 - Input Speed sensor circut, P0763 - Shift solenoid C (#3) electrical and P1349 - VVT System Malfunction Bank 1. The dealer wants to charge me upwards of $500 to pull the transmission pan just to check the transmission.....IF it is the transmission. The car has been running good. Recently Lexus changed:
Entire Throttle Body
Altinator
Solenoid #1
Power Steering Pump
Resealed Gaskets
Transmission Fluid Flush
In addition, I had the Brake Booster replaced, new starter, Emergency brake assymbly and new tires.
I don't want to shell out unneccessary dollars to the dealer if this is a minor fix. Help!
If the mileage is high my first thought is the wiring has become dried out and brittle and with all the previous work poor connection and broken connectors is where I would start.
The P0715 and P0763 look at the harness plug in to the transmission ( for the valve body ) for corrosion.
The P1349, OCV connection first , ( w/r and blue/black) .
Or blockage in oil control valve, remove and clean.
Check valve timing ( was timing belt just done)??
Check ECM connections for loose or corrosion -- wiggle test.
Make sure battery cables are perfect, no voltage drops no corrosion and no stupid *BLEEP*.
Make sure all ground on intake manifold are intact and perfect.
I really hope this helps none of these problems are " typical".
