Mikes515 Posted November 25, 2012 Posted November 25, 2012 Got a 93 ls400, although I know this issue is general and that the model and year dont 100% matter. My driver side electric seat is almost fully functional. It goes every which way except half the back is stuck in one spot. When i try to lean the seat back only the left half moves back. This has tweaked my back quite a bit.... I dont like to keep my seat back so straight up and am not use to it or just half of it being straight up. I did google a few different things but the answers seem to be quite vague. If anyone has any info or a site with info it would be greatly appreciated. :)
escee Posted December 11, 2012 Posted December 11, 2012 Mike... I just experienced the same exact problem with a 92 LS400, on the same day it seems... is that one hell of a coincidence? Did you find any solution to this problem?
1990LS400 Posted December 11, 2012 Posted December 11, 2012 The problem is caused by a warn shaft/sprocket in the lower seat back or thereabouts - very common problem. Some people are able to fix and reuse the shaft/spocket. I had the one on the 90 LS I used to have replaced. I think I paid my mechanic around $100 for the fix including the new part but that was maybe 15 years ago. I'm sure there are photos and details on this forum on how to fix the problem. Try searching this LS400 forum. Edit: I found this tutorial on Clublexus by using Google to search on "LS400 driver seat tilt problem": http://www.clublexus.com/forums/ls400/442318-how-to-fix-the-problem-with-non-working-reclining-on-drivers-seat-pictures-inside.html
escee Posted December 11, 2012 Posted December 11, 2012 Thanks man, that looks like it! This was an awesome present to find here in the morning. I swear either I, or google, used to be better!
