slstsang Posted March 8, 2004 Share Posted March 8, 2004 Hi All, where is the IACV located? can someone snap a pic for me so that i can clean it our myhself? is it hard to take it apart? Quote Link to comment Share on other sites More sharing options...
oldrx300 Posted August 13, 2004 Share Posted August 13, 2004 Hi, Did you able to find a picture of IACV? I'm looking for it myself, just wonder if you already found it. Thank you. Quote Link to comment Share on other sites More sharing options...
amf1932 Posted August 13, 2004 Share Posted August 13, 2004 The IACV is located under the throttle body so it would be pretty tough to shoot a photo. Personally, I never tried to remove this valve, but it was suggested that you should remove the throttle body to gain easier access. Maybe SK can help.....he's constantly ripping apart his engine. hehehe Quote Link to comment Share on other sites More sharing options...
oldrx300 Posted August 17, 2004 Share Posted August 17, 2004 Found it. Took out the 2 air intake hoses and the IACV locates right under them. I took out the two screws and cleaned the inside with the throttle body cleaner. The problem went away, so here is the pictures I took (IACV is the black piece with the two screws, one of them has the yellow dot on it). Thank you. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 18, 2004 Share Posted August 18, 2004 hmm ,now we have a pic,i thopught someone else posted a complete one with pics as well a bit ago. I don;t rip my engine apart ever, thank goodness Quote Link to comment Share on other sites More sharing options...
todd332 Posted May 3, 2007 Share Posted May 3, 2007 So to Clean the IACV , I remove those two screws that look like its Holding on a Small Box of somesort ? If thats it , Do I spray Carb Cleaner on it Directly or inside it? Thanks Quote Link to comment Share on other sites More sharing options...
TroyLexus Posted April 8, 2009 Share Posted April 8, 2009 So to Clean the IACV , I remove those two screws that look like its Holding on a Small Box of somesort ? If thats it , Do I spray Carb Cleaner on it Directly or inside it? Thanks Thought I would bump this post, because I have the same question, no where near an expert with cars, Is Carb Cleaner and throttle body cleaner the same thing ? do I spray directly on it, or inside ? Do I remove the screws that look like its holding on a small box of somesort ? thanks !! Quote Link to comment Share on other sites More sharing options...
camlex Posted April 8, 2009 Share Posted April 8, 2009 buy TB cleaner and spay inside that hole. Quote Link to comment Share on other sites More sharing options...
homemechanic Posted April 9, 2009 Share Posted April 9, 2009 Someone had posted a very nice write up with pictures on how to clean IACV. It was probably 2 years ago. It shows every step of the way w/pictures. You should search for this post before start taking things apart. Quote Link to comment Share on other sites More sharing options...
TroyLexus Posted April 12, 2009 Share Posted April 12, 2009 Someone had posted a very nice write up with pictures on how to clean IACV. It was probably 2 years ago. It shows every step of the way w/pictures. You should search for this post before start taking things apart. was that right up you speak of on these boards in particular ? or should I search on google ? Quote Link to comment Share on other sites More sharing options...
homemechanic Posted April 12, 2009 Share Posted April 12, 2009 Someone had posted a very nice write up with pictures on how to clean IACV. It was probably 2 years ago. It shows every step of the way w/pictures. You should search for this post before start taking things apart. was that right up you speak of on these boards in particular ? or should I search on google ? it's on this forum.. search the key words:: IACV, idle control valve. .etc Quote Link to comment Share on other sites More sharing options...
Lexlogic Posted April 13, 2009 Share Posted April 13, 2009 [attac hment=12292:Throttlebody2.jpg] it's on this forum.. search the key words:: IACV, idle control valve. .etc Quote Link to comment Share on other sites More sharing options...
cales300 Posted April 20, 2009 Share Posted April 20, 2009 [attachment=12292:Throttlebody2.jpg] it's on this forum.. search the key words:: IACV, idle control valve. .etc I have a 97 es300 and it doesnt look like the TB pictured. I would like to clean out the IACV but would like some info on the specific setup I have. Quote Link to comment Share on other sites More sharing options...
camlex Posted April 20, 2009 Share Posted April 20, 2009 Long time ago, somebody posted how to check IACV. Test port next to radiator cap, short TE1 and E1 and rpm runs fast your IACV is working properly. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Bk4293 Posted April 20, 2009 Share Posted April 20, 2009 Actually on the 92 ES300 it's a bit simpler than that. It's located on the intake manifold near the throttle body (Since the original poster has a 92 ES 300. But hopefully he found it by now.....Five years later... :P 2 bolts (12mm I believe) and a bunch of hoses. IACV Intake Air Control Valve $370.00 at your local Autozone Quote Link to comment Share on other sites More sharing options...
cales300 Posted April 22, 2009 Share Posted April 22, 2009 Heres a pic of the TB on my 97,it doesnt look as easy to remove as the one pictured earlear in this thread... And here is what I was thinking might be the IACV? Has anyone cleaned or replaced one on a 97? Quote Link to comment Share on other sites More sharing options...
firer Posted June 7, 2009 Share Posted June 7, 2009 Actually on the 92 ES300 it's a bit simpler than that. It's located on the intake manifold near the throttle body (Since the original poster has a 92 ES 300. But hopefully he found it by now.....Five years later... :P 2 bolts (12mm I believe) and a bunch of hoses. IACV Intake Air Control Valve $370.00 at your local Autozone Great picture, thank you. Can this valve be cleaned, and if so, are their any special instructions or do I just spray it with carb cleaner. Quote Link to comment Share on other sites More sharing options...
Qis30003 Posted August 10, 2009 Share Posted August 10, 2009 Found it. Took out the 2 air intake hoses and the IACV locates right under them. I took out the two screws and cleaned the inside with the throttle body cleaner. The problem went away, so here is the pictures I took (IACV is the black piece with the two screws, one of them has the yellow dot on it).Thank you. I see that you took out the IACV and cleaned it out and you said the problem went away, What was the problem you were having if you don't mind me asking? i know this post is a few months ago but i was told to clean mine out because i'm having misfire problems in cyl 1,2,3 Quote Link to comment Share on other sites More sharing options...
