Power Ect/ Overdrive Shift
always leave the o.d on all the time as it is better for fuel and shifting.
The ect button is useless as it only changes the shift points for a wider powerband but usues more gas .If you wan tthe same power just press the gas all the way for the same shifting.
On my LS, I've used the ECT switch whenever I press the fuel pedal and the performance is really slow.
It gives me a little boost, if i need it, but it does apply more fuel to the block.
