Hi all, I have been searching for a long time. Can any one share with me. I will be very grateful.
I recently bought an used 2003 es 300. The horn alarm for the remote control (keyless entry on the key) is missing. When I lock or unlock my car, there is no "beep". I would like to have it DIYed. But I can not do it without a repair manual. All comments are appreciated.
Also my email: mit.camoufleur@gmail.com
Thanks.
Thanks.
you may check the horn alarm's wire . if it's broken, you have to connect wire by yourself. you may use the tool like rubberized fabric and scissors
Thanks.
Thanks so much for the info. Do you know where that part is? I checked my car and can not figure out where the alarm should be. That is the reason why I want a repair manual.
Btw, I think the horn itself for the alarm is missing.
Setting the keyless entry "beep" on or off is a customizable feature per the 2003 ES300 owners manual: http://drivers.lexus...03is300o/11.pdf
Locking/Unlocking the doors
When you push the ”LOCK” button on the key briefly, all
the doors will be locked from outside the vehicle.
At this time, one beep sounds* and the emergency flashers
flash once.** However, when you push the ”LOCK” button with
any door not closed securely, the buzzer sounds for 10
seconds.*** To stop the buzzer, close all the doors securely or
push the ”UNLOCK” button. If the key is in the ignition switch,
locking cannot be done.
Make sure all the doors are locked when you leave the vehicle.
Push the ”LOCK” button once again. If they were already
locked, one beep sounds and the emergency flashers will
flash.
NOTE: *The beep sound can be set not to sound. **The
emergency flasher can be set not to flash. ***The buzzer
can be set not to sound if a door is not closed securely. Ask
your Lexus dealer for details.
