GSLike Posted April 5, 2012 Posted April 5, 2012 I Bought a used 2006 GS300 about 1 months ago. After about 1 week the check engine light came on plus Check VSC message and traction light as will and the transmition shifting is not smooth i Took it to the Lexus dealer, and they said that i have to change the solonid and the bodyvalve of the transmition gear and this is too costly can any body advise?
abriel Posted April 9, 2012 Posted April 9, 2012 I Bought a used 2006 GS300 about 1 months ago. After about 1 week the check engine light came on plus Check VSC message and traction light as will and the transmition shifting is not smooth i Took it to the Lexus dealer, and they said that i have to change the solonid and the bodyvalve of the transmition gear and this is too costly can any body advise? it may be a bad parking brake switch, low level of brake fluid or a bad brake light switch.
Dave Shaver Posted April 15, 2012 Posted April 15, 2012 As stupid as it sounds, try tightening or replacing your gas cap. If the cap is leaking, your car may go into "protection mode". I had my Toyota Van (2011 Sienna) do this exact thing; the check engine and traction control lights came on. Fixed by tightening gas cap.
Carlos A Gomez Rosa Posted April 20, 2012 Posted April 20, 2012 Tightening the cap fixed it for me. 2004 LS 430.
boB_2006_GS300 Posted April 20, 2012 Posted April 20, 2012 make sure you have a good battery as the transmission shifts electronically. also make sure all of your fuses are good.
