onlyone Posted March 18, 2012 Share Posted March 18, 2012 I've had my lexus for 11 years now.....but last week I went out to star it and nothing.lights came on but no crank no nothing just lights....no attempt of turning over...just dead silent...battery is good ,gas and everything I thing possible good.a little mechanically incline , but just don't have a clue now... Quote Link to comment Share on other sites More sharing options...
dcfish Posted March 19, 2012 Share Posted March 19, 2012 Take the battery cables off and brush the terminals and the cables clean, Reinstall and make sure they are tight... Quote Link to comment Share on other sites More sharing options...
onlyone Posted March 20, 2012 Author Share Posted March 20, 2012 Tx I will try to do that, any help works.ill see if I have some luck. Quote Link to comment Share on other sites More sharing options...
silverbullitt Posted March 21, 2012 Share Posted March 21, 2012 A cool trick I use cuz sometimes my cables use to get loose. I use aluminum foil. Place some around the post after u cleaned everything, then wrap enough around the post. Then reinstall your cables, tighten it up & your go to go afterwards. Should have no more problems. Quote Link to comment Share on other sites More sharing options...
onlyone Posted March 30, 2012 Author Share Posted March 30, 2012 Well no luck on my car....still the same.some one told me that the starter mit not be working right, not getting the voltage but nothing it tested out good....so still clueless on it....so anybody with new ideas...... Quote Link to comment Share on other sites More sharing options...
silverbullitt Posted April 20, 2012 Share Posted April 20, 2012 your starter mite be gone or the wiring to the starter is loose. have them checked Quote Link to comment Share on other sites More sharing options...
dcfish Posted April 21, 2012 Share Posted April 21, 2012 I had to replace my starter contacts about 8 years ago, Maybe the culprit... Quote Link to comment Share on other sites More sharing options...
onlyone Posted May 1, 2012 Author Share Posted May 1, 2012 Well the problem........the car had the stock alarm activated and even if you put the main key in, it did not deactivated..the solution was..just disconnect the negative from the battery and leave it over night...put back and stared right up..that was it... Quote Link to comment Share on other sites More sharing options...
HalfWay023 Posted June 30, 2012 Share Posted June 30, 2012 Wow i have had my gs300 for a year and it never gave me not 1 problem... Then one day i throw my keys to my girlfriend n she dropped em and the chip came off the key the blade was fine tho... tried to start car an nothing (as u described EXACTLY!)..had mechanic re soder the chip and it started rite up... well over time the key ended up breaking again and again but the car still started just fine so i been driving it like that for months but then i go to the store yesterday and came out and it did it again i tried everything and cant seem to get it to turn over well i gave up and decided to unhook the battery cables off the battery just hoping tomorrow it will js start up... but i took both of them off not just the neg. do u think thats gonna be a issue... and a lexus dealership also told me that the whole chip gotta match computer thing wasnt put in till 98 and up... but i really hope that solves my probem.. Anyway so do u think it will stll work even tho i took both cables off? Quote Link to comment Share on other sites More sharing options...
