Wee Bit Confused
funky
was following the diy spark plug for change of rear spark plugs on my 2000 rx300.. took my time too.. been over 3 weeks.. mostly because after i had the car opened up it.. weather decided it was time for rain in texas.. hasnt rained all yr! anyways.. removed the throttle body / intake plenum ... and have got them back on.. but stuck on hoses and vacuum connections.. i marked them with colored tapes since i was hoping to finish it in a couple of days max... but most of the tapes are now peeled off and have left me in a fix as to where which hose or which vacuum line goes... is there any diagram i can refer to ensure i get everything back on in order.. ?
thanks!
ad
there is a vacuum line diagram under the hood by the latch, look up....
haha you are right.. that solved the vacuum line issue.. working on the coolant hoses now . never worked on my car before.. so its an experience in itself! as long as it dont blow up or something when i goto start it i suppose.. thx a ton!
  • 8 months later...
Why did you remove all that stuff? I worked around the plenum, though i did remove the air box boot. And i needed to remove the EGR valve on the passengers side near the firewall. Anyway, the whole job, w/o removing the plenum took 3 hours and i am not a mechanic.
