vikingjz Posted January 14, 2012 Share Posted January 14, 2012 Hi all, I bought a 1995 LS400 last week. No huge issues except for a noise in the back of the car. When you are driving, if you are coasting and punch the gas, the rear end makes a THUD sound. I was told it could be some sort of mount. If you drive normally or under light acceleration, it is fine and drives smooth and silky. No other noises or problems Transmission mount? Some sort of rear end mount? Quote Link to comment Share on other sites More sharing options...
pj8708 Posted January 14, 2012 Share Posted January 14, 2012 Hi Aaron. Just wanted to say welcome to the club and let you know that your post has been acknowleged. I don't know the answer to your question, but others will chime in here and help you out. Again, welcome. Paul Quote Link to comment Share on other sites More sharing options...
landar Posted January 14, 2012 Share Posted January 14, 2012 It could be a mount, bushing or joint along the driveshaft line. The transmission mounts are notorious for cracking. Changing that mount is fairly easy and almost a maintenance item if it has not been performed in the last 8 years or so. If you are handy and do your own work, you would need to crawl under the car and do some inspecting. Or what I would do, and is much safer and more convenient, is take the car to a trusted shop and explain the issue to them. They can easily put it on a lift, do a quick inspection and probably tell you what the problem is. Then you can decide if you want to tackle the fix or have them do it. Most shops will do the inspection for free and if not, it is only a few bucks. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted January 14, 2012 Share Posted January 14, 2012 Have you checked for "junk in the trunk"? No, not the size of your butt - whether or not there is something rattling around under spare tire well or under the false floors on either side of the trunk. And make sure that the jack and it's handle are securely stowed in the spaces provided. Quote Link to comment Share on other sites More sharing options...
billydpowell Posted January 16, 2012 Share Posted January 16, 2012 Hi Aaron. Just wanted to say welcome to the club and let you know that your post has been acknowleged. I don't know the answer to your question, but others will chime in here and help you out. Again, welcome. Paul Hi Paul, seems like I have met you somewhere, not sure but you look familiar. have a great day.. Quote Link to comment Share on other sites More sharing options...
pj8708 Posted January 16, 2012 Share Posted January 16, 2012 Hi Aaron. Just wanted to say welcome to the club and let you know that your post has been acknowleged. I don't know the answer to your question, but others will chime in here and help you out. Again, welcome. Paul Hi Paul, seems like I have met you somewhere, not sure but you look familiar. have a great day.. Good to see you Billy! I think the face lift has done wonders for me don't you? Quote Link to comment Share on other sites More sharing options...
vikingjz Posted January 16, 2012 Author Share Posted January 16, 2012 Thanks guys. I can do most if not all the work myself. I just wanted to check the problem out online to see if anyone had similar experiences. Quote Link to comment Share on other sites More sharing options...
jaswood Posted January 16, 2012 Share Posted January 16, 2012 Hi all, I bought a 1995 LS400 last week. No huge issues except for a noise in the back of the car. When you are driving, if you are coasting and punch the gas, the rear end makes a THUD sound. I was told it could be some sort of mount. If you drive normally or under light acceleration, it is fine and drives smooth and silky. No other noises or problems Transmission mount? Some sort of rear end mount? The rear diff'l has 3 rubber mounts/cushions. My '95, approaching 300K just had these replaced, DIY. Was experiencing the "thud" with quick on or off of the throttle, plus transmission "dithering" back and forth in gears at 40-50 just cruising along. Quote Link to comment Share on other sites More sharing options...
vikingjz Posted January 16, 2012 Author Share Posted January 16, 2012 Cool thanks. Where did you buy the rubber pieces from? Quote Link to comment Share on other sites More sharing options...
billydpowell Posted January 17, 2012 Share Posted January 17, 2012 I copied these photos from our forum, have not done this, but wanted to keep them just in case.. hope it helps you Quote Link to comment Share on other sites More sharing options...
jaswood Posted January 17, 2012 Share Posted January 17, 2012 Cool thanks. Where did you buy the rubber pieces from? Ebay or Carson city Toyota. You can check the outer wheel bushings by trying to move the wheel hub back and forth with the car on jackstands. Quote Link to comment Share on other sites More sharing options...
