COMike Posted November 28, 2011 Posted November 28, 2011 This may seem like a silly question but our RX driver's side sun visor does not stay up. You push it up into the recess of the ceiling headliner and it falls down to about a 45 degree angle. Constantly gets in the way of your vision and you almost always hit your head on it when getting into the vehicle. I have looks and looked at a way to tighten this up all to no avail. Does anyone know of a way to make this tighter or will I just have to buy a new one? Anyones help and advice is appreciated
carguy07 Posted December 2, 2011 Posted December 2, 2011 http://us.lexusownersclub.com/forums/index.php?showtopic=55962
proudrx300 Posted December 2, 2011 Posted December 2, 2011 This may seem like a silly question but our RX driver's side sun visor does not stay up. You push it up into the recess of the ceiling headliner and it falls down to about a 45 degree angle. Constantly gets in the way of your vision and you almost always hit your head on it when getting into the vehicle. I have looks and looked at a way to tighten this up all to no avail. Does anyone know of a way to make this tighter or will I just have to buy a new one? Anyones help and advice is appreciated Hi Michael, Sun-visor issue is a common concern amongst Lexus owners. I too have the same problem. Only remedy is to replace with a "new" (strongly against it. Too expensive), or a used one that still stays up. Roland
boyag Posted January 6, 2012 Posted January 6, 2012 Had the same problem on my rx300, short of replacing you can use a plyer to crimp a section of the visor where the rod goes into it about 2 or 3 inches from the point of insertion. You may have to do this a couple of times.
Rogerm Posted December 7, 2014 Posted December 7, 2014 Velcro same color Glue with Elmers and tape with painter tape until dry. Cheap Easy Works Mine is still fine after a year.
