Halim Posted May 27, 2011 Share Posted May 27, 2011 Last Sunday I finished Led turn signal mirror covers. Red circle is flasher. Blue circle (Green wire with black tracer) is left turn signal output. Yellow circle (Green wire with a yellow tracer) is right turn output. You need to connect those for positive wires of L/R Led mirror cover. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Flasher located next right to the interior fuse box driver side. This flasher located under the steering near the fuse box to the right side. You need to pry the plastic trim under the steering by removing 2 nuts (10mm) lower left and right ( this one hide with small plastic trim need to open by flat screw driver. There is another iron cover need to remove by 2 (10mm) screw on left and right side also. Use heavy cotton gloves, lower side of the cover is very sharp. Then you will see the flasher. Red arrow is the iron cover. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Right turn signal connected. I will show you how I connected with right turn led signal cover. Red circle is extra fuse connected with flasher wire (green with yellow tracer). Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 I removed the U shape wood trim ( pry from the bottom to up) by the radio/ac and run this wire behind the glove box to the right side. This mirror glass need to pry from the bottom to up by red arrows using two hands. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 You will see like this. Green tape is the one of the connection for heated glass. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Door panel need to remove. Follow this link to remove. :http://www.clublexus...emoval-diy.html You will see this and yellow line area need to pull by hand. Another pic of blue plug for mirror, unplug it. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Removing mirror from the doorRemove this mirror holder cover. See those 3 (10mm) bolts holding mirror. Remove those. PICS: 1 & 2.PICs 3 & 4 mirror removed. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Arrow marked plastic cover need to pull out. Follow pics 1. Remove those kind of three screws (red circle) pic 3. Remove (blue circled) three screws also pic 4. Finaly you see this after removed six screws pic 6. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 LED mirror cover. You need this red and black wire run by mirror power cable to the door (pic 1). Run this wire by the hanger (pic 3 & 4). Finaly you see this (pic 5) Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Drill old mirror cover.Our RX 300 has no extra mirror cover. So drill your old cover almost same size of led wire at the left side.(see pics) Solder the wire connections and taped. Remove the led mirror cover 3m tape and sit on the top of old cover nice and smoothly. Install the mirror glass back by soft press with towel on the white plastic frame.(see pics) Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Run wire through door cable insulator to door. Behind the glove box locate the flasher connected red wire (which already run) and run through the door cable insulator at the right with black ground wire to the door. I use a body trim bolts as a ground and works. (see pics) Remove the speaker before you run the wire to the door. It will make easy and I used a hanger for run the wire. Here you will see the ground wire and speaker. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Final stage.Now bolt the mirror same position with three (10mm) bolts. Connect the blue plug with the harnesse and solder the led wires with flasher and ground wires. Attached the blue plastic and door cover. You done. (see pics) Quote Link to comment Share on other sites More sharing options...
Halim Posted May 27, 2011 Author Share Posted May 27, 2011 Pics of my rx 300 Here is some pics of Led turn signal mirror cover of my RX 300 with my daughter. Quote Link to comment Share on other sites More sharing options...
cduluk Posted May 28, 2011 Share Posted May 28, 2011 WOW! Thanks for posting these pictures, i don't believe anyone else has posted a "how-to" for this modification. I think i'm gonna add some LED mirrors on my RX400h, so hopefully it'll work the same way! Quote Link to comment Share on other sites More sharing options...
Halim Posted May 28, 2011 Author Share Posted May 28, 2011 I hope it will work for you. Check your mirror cover before you do this. May be you have extra outer cover and it is easier. For your car you could buy led mirror cover from this side: http://www.nigel-jdmparts.com/LED-Turn-Signal-Mirror/2004-2009-RX330350400h Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted May 28, 2011 Share Posted May 28, 2011 Halim, that is an absolutely excellent tutorial. Maybe you will have to do another tutorial about that Parrot phone kit you installed in your RX! ... couldn't resist saying that. Really, that was an excellent job. Quote Link to comment Share on other sites More sharing options...
Halim Posted May 29, 2011 Author Share Posted May 29, 2011 Thanks Jim. I will try to do it . Quote Link to comment Share on other sites More sharing options...
