prix Posted February 22, 2004 Share Posted February 22, 2004 Just wondered if there is anything on the market for the problem (temporary fix). Not ready to replace the rack...only see about a 2" drop of fluid on garage floor on occasion. Have been advised it is leaking by mechanic. Also have heard/read on some sites that it's a good idea to replace pump, rack and hoses all at same time, as if one element gets contaminated, could effect all others. I had a hose leak, and only replaced the hose. I now have a minjoir power steering leak. Not sure I see the connection, or why 'contaminated' fluid could effect a big metal part. Thoughts? Should I replace all at once? That would be tres cher (expensive!) Quote Link to comment Share on other sites More sharing options...
jzz30 Posted February 22, 2004 Share Posted February 22, 2004 you can try and buy one of those conditioners for your power steering Quote Link to comment Share on other sites More sharing options...
bamalexusguy Posted February 26, 2004 Share Posted February 26, 2004 I used Lucas Power Steering fluid with stop leak. It stopped the leak and quietened the power steering pump and hard spots. I got it at Advance Auto parts. Quote Link to comment Share on other sites More sharing options...
yucaton_tom Posted November 1, 2004 Share Posted November 1, 2004 I agree on the Lucas additive: it is about $6 a bottle at O'reilly's here in Houston, but you will notice instant improvement. They offer a money back guarantee after using two bottles of it - I was skeptical even though it slowed down the leak right away. Now, at about 1.5 bottles being run through, I think the leak has stopped. What do you have to lose? Tom Quote Link to comment Share on other sites More sharing options...
kcpth Posted November 1, 2004 Share Posted November 1, 2004 My mechanic doesn't like the use of those products. He said that those products can create more problems later on. He said that it may clog the whole system. But if you want a temp fix... i suppose thats not bad... n if u plan to change the whole system later when you have the $$$, then its fine. But then again i understand y he may tell me that he doesn't like the use of the products... probably b/c he can also squeeze some money off of me. Hahahaha. But he may be right too. Let me tell u... the Power Steering pump is $$$$.... n i'm sure the Rack n Pinion is going to b a heck of a lot more than the P/S pump. Quote Link to comment Share on other sites More sharing options...
92Lex Posted November 1, 2004 Share Posted November 1, 2004 I too like Lucas products, but if you're able to cough up the money to replace the steering rack and pump then by all means do so. A temporary fix is just a temporary fix...all the Lucas power steering stop leak stuff does is it swells up the seals in your system. Quote Link to comment Share on other sites More sharing options...
