babyduke Posted April 1, 2011 Posted April 1, 2011 2009 ES350 w/Navigation How do you control the vent in rear seating? I turned the heat on to about 74 then opened the vent all the way in the rear but I feel very little warm air.
1990LS400 Posted April 2, 2011 Posted April 2, 2011 OK, you've got a "new to you" car. Maybe it's time to read your owners manual to discover in which HVAC modes the various rear seat vents function and to learn about the many features of your car.
babyduke Posted April 4, 2011 Author Posted April 4, 2011 I always refer to the manual first then if I can't find an answer, I try it here.
pj8708 Posted April 5, 2011 Posted April 5, 2011 I always refer to the manual first then if I can't find an answer, I try it here. If I understand what your saying, you have read the manual, but still can't find the answer. You say you set the temp to 78. Was the A/C in the ON mode or OFF mode. What position was the air intake set for; fresh air or re-circulate? Last, I know you turned the dial on the vents up and down to make sure it was open? On my 2010, the fan puts out the most force to the rear vents when the control is set for just upper body.Page 202, ES350-2010 owners manual. Any other setting, i.e., defrost, feet and dash vents, etc. have a lesser amount of air flow to the rear vents. It never puts out a lot of force. Not sure if this matters, but when it gets around 32' outside the A/C compressor may not run. If the outside air intake is in the re-circulate position I don't believe the system blows any air except for the dash vents. Again page 202 and 205. This is the same regardless of having Nav or not. The great thing about this forum is that someone might come along with some better answers. Paul
