Sign in to follow this
Mr Bill
O2 Sensor Change A Good Idea?
My 96 ES300 has just over 100k miles. Despite a high reading (50 out of a max of 51 ppm hydrocarbons) 2 years ago, it just passed a smog check again today.
Given that to change the 3 O2 sensors is something like $400 or more, should I go ahead and change them to protect the catalytic, or just wait until I get a CEL??
Thanks to those who responded to my other O2 sensor question on resetting the ECM.
Thank you
Bill
Share this post
Link to post
If the actual o2 sensors readingas are normal when hot then don;t change them you are only wasting money
get a motorvac done and clean all of tehm including the cat
Share this post
Link to post
A high pressure fuel rail treatment
it uses a machine and the gas tank is shut off and it runs off the machine with higher pressure nad a solution
it cleans the crap out of the engines rails valves intake exhaust manifolds cat and exhuast as well as the combustion chamber.
For about $100 it will 100% make the car dirve like a whole new one
totally different froma basic fuel aditive.
Share this post
Link to post
atleast once every 2 years
or a week or so before an emmision test if needed in your area as it is almost a guarnteed pass after
Share this post
Link to post
Loading...
