stroker Posted September 17, 2010 Share Posted September 17, 2010 Good morning all... I have a new warning light on my dash. Its the brake light with the Exclamation point in it. It only comes on if I really accelerate fast from a stop and by the time I level off the gas pedal it goes out. No idea what causes it, brakes are fine and the e-brake is never on.. Any help is appreciated. Thanks, Bobby Quote Link to comment Share on other sites More sharing options...
intakerGS Posted September 17, 2010 Share Posted September 17, 2010 Check your brakefluid reservoir (and fill-up between low/high markings). If a bit low, the level sensor triggers a warning, especially when braking/revving (fluid fluctuates). Quote Link to comment Share on other sites More sharing options...
PaulS Posted November 4, 2010 Share Posted November 4, 2010 I am having the same problem with my brake light coming on and the brake fluid reservoir is on full and looks clean. Any other ideas on what to check would be appreciated. Thanks, Paul Quote Link to comment Share on other sites More sharing options...
lexfourcam Posted November 4, 2010 Share Posted November 4, 2010 I have the same exact problem as well. It's been happening for a long time and like you my brake reservoir is full. A solution to this problem would be great! Quote Link to comment Share on other sites More sharing options...
99lsguy Posted November 4, 2010 Share Posted November 4, 2010 Try pulling the sensor and cleaning it up a bit. Shoot some air in the socket to clean..... and check for loose wire and/or connection. Quote Link to comment Share on other sites More sharing options...
hugo831 Posted November 4, 2010 Share Posted November 4, 2010 I am having the same problem with my brake light coming on and the brake fluid reservoir is on full and looks clean. Any other ideas on what to check would be appreciated. Thanks, Paul just try to top it of whit brake fluid up to max,if consistant it might be a problem whit your emergency brakes.. Quote Link to comment Share on other sites More sharing options...
PaulS Posted December 2, 2010 Share Posted December 2, 2010 I am having the same problem with my brake light coming on and the brake fluid reservoir is on full and looks clean. Any other ideas on what to check would be appreciated. Thanks, Paul just try to top it of whit brake fluid up to max,if consistant it might be a problem whit your emergency brakes.. The rear pads/rotors were completely worn and the emergency brake pads were also worn and the cable was seized. All the pads,rotors, and cable were replaced and the brake fluid topped up. The brake light has not come on since. What a difference in the braking too! Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
landar Posted December 2, 2010 Share Posted December 2, 2010 The rear pads/rotors were completely worn and the emergency brake pads were also worn and the cable was seized. All the pads,rotors, and cable were replaced and the brake fluid topped up. The brake light has not come on since. What a difference in the braking too! Thanks for the tip. Paul, glad to hear that you got her fixed. Thanks for following-up with the solution to your issue. Quote Link to comment Share on other sites More sharing options...
