emalo54321 Posted June 14, 2010 Posted June 14, 2010 i just bought a 1998 gs400. overall amazing purchase. i couldnt be happier. i realized that there is a nakamichi amp in the trunk. i want to put either a 10" or a 12" subwoofer in the trunk. would the stock amplifier have enough power to supply either a 10" or a 12"? or would i have to buy another amp? thanks for your input
Infamous 1 Posted July 7, 2010 Posted July 7, 2010 If you are planning on replacing the factory sub, then yes the amp will work as long as the wattage is the similar.
lexusman17 Posted September 19, 2010 Posted September 19, 2010 i just bought a 1998 gs400. overall amazing purchase. i couldnt be happier. i realized that there is a nakamichi amp in the trunk. i want to put either a 10" or a 12" subwoofer in the trunk. would the stock amplifier have enough power to supply either a 10" or a 12"? or would i have to buy another amp? thanks for your input ive got a 98 gs300 with two 12's i would run with a seperate amp just for the fact that your subs would sound better with a bigger amp
TRDGS300 Posted October 4, 2010 Posted October 4, 2010 lexusman is right. run another amp. wouldnt chance it with the stock one.
SKperformance Posted October 6, 2010 Posted October 6, 2010 the stock amp couldn't push an aftermarket 5inch full range cone. The amp is made for efficiency not power . Get an after market amp and sub if you want more . Otherwise a new sub will give you less with the oem amp .
