When I start my car, it sounds noisy (like a Volkswagen), but when you step on the accelerator, you need ear plugs. The further you step on the accelerator the louder it gets. It also doesn't seem to have that much power any more. Does it sound like an exhaust problem??
Model: ES300
Year: 1994
Mileage: 101000
It sounds like the exhaust system rusted out. Put the car up on a lift and see where the noise is coming from. ;)
Sounds like a broken exhaust manifold gasket or cracked manifold. Low power could be from a clogged catalytic converter in combination with manifold problems. Continued driving when the engine is performing this badly can result in serious engine damage. So the car should be parked and keep your fingers crossed that no lasting damage has occurred.
go to speedy or midas or one of those for a free estimate
use only toyota exhaust parts not there cheap ones
it is more than likely a bad flex joint that is leaking and getting worse
the y pipe usually breaks because of driving over something or more often because of a broken engine mount causeing too much flex and breaking it
about 350 for the part and 100 labour
Thank you all for your help! :D
I went to Exhaust Pro this morning. The problem is broken engine mounts. So...they contacted Lexus to get the parts and it will be fixed by Monday :( (I'm not very patient).
Thank you all agian! You were a great help!
