selly Posted May 15, 2010 Posted May 15, 2010 Hi from the UK, I have USA spec Lhd 2007 Lexus IS350, a company in the USA set me over a new rack and pinion, fitted and was overjoyed when power steering came back to life again, so got my snapon solus pro out and tried to reset the fault code c1515 and c1525, Lexus is not on the Snapon menu so did it has Toyota, got half way through the zero point reset and scan tool said error, the steering then went into fail safe and electric power stearing cut off and p/s light came on, i,m told i can do a manual reset by croosing pins on the dlc3 connecter and i have tried all the ones ive found on the net but no good, can anyone help with a reset procedure for this zero point calibration reset..thanks
sktn77a Posted May 29, 2010 Posted May 29, 2010 Bite the bullet and take it to the dealer to be re-set.
