Sc430 Shock Absorbers
gkayvee
My '05 SC430 is about due for new shocks--starting to get a little bottom-out in front on speed bumps at 1 mph. What are your recommendations for a replacement shock that might tweak the handling a bit without making the ride too much stiffer? Also, would you replace the coil-over springs at the same time, and if so with what? Thanks...
