Ls 400 Motor & Transmission Mounts
dogboy
:ph34r: I have a 91 LS 400. I would like to replace the motor mounts and the transmission mount. I have looked all over the place and the best price I have found on the (Part # 1236150100) Motor mounts is $110.15 per mount, and $71.30 for the transmission mount. Does any one know where I can find these parts cheaper and how hard is it to do yourself? Also should I just replace the bushings and not the whole mount?
  • 5 months later...
Tranny mount is a piece of cake to do. Engine mount is a bit more work, only because getting access to the upper bolt on each mount is a bit tight. Give yourself an hour and a half if you haven't done this sort of thing before and you should be in really good shape.
