jmusiclove Posted January 26, 2004 Posted January 26, 2004 anyone know how to take out the oil filter from above(not bottom)...or the right way to remove oil filter from IS300???
Gr8JuliusCaesar Posted January 28, 2004 Posted January 28, 2004 I usually just reach in form the top driver side and take it out it's a pretty tight squeeze but it'll come out. just my 2 pennies.
az17invas1on Posted May 24, 2004 Posted May 24, 2004 yea i agree.. i recently changed my oil filter and i had to reach in from the top... the bad thing about changing your oil filter on the is300 is that oil leaks everywhere to the bottom.... is there anyway you can prevent oil from leaking down all over the engine parts n stuff ??
bbsal Posted May 25, 2004 Posted May 25, 2004 you can try maybe a towel under it so it leakes onto that instead of the motor but i know what you mean.i had a mazda that loved to leak all over the engine when you changed the filter but used a towel and it solved the problem.
jimcyzfr1 Posted June 4, 2004 Posted June 4, 2004 take a large piece of plastic like a for sale sign and roll it up to funnel shape or buy a trans fill funnel long and slender, snake it down or up from bottom into position then quickly drop filter into full let oil drain onto filter and into funnel, funnel should b long enough to let you aim all oil off of components and into pan waiting at bottom, better yet place a 1 foot lengh of heater hose on end of funnel and that way it will flow all the way out of undercarriage no mess.it works great if done right.
axle13 Posted November 9, 2004 Posted November 9, 2004 Just my 2 cent's, but i used a small bag of chips, after i ate them of course, placed bag over filter, and removed filter with bag around it. worked great for me, and served as a snack while oil was draining out of the pan.
