I have posted this on the UK club but thought you Guys over the pond should also see it.
I've even used the US equivalents :D
With 100,000 KMs (60,000 miles) now achieved I have been meaning to do a transmission fluid change for some while now, it just annoyed me that in the USA I could buy 12 quarts of Toyota Type IV for a mere £26.00 ( $44.00 Ebay.com) but over here it has cost me £88.00 ($146.50) for 10 litres ( 10.5 quarts) of the stuff and that was with a 10% discount from Sean at Lexus Derby.
Anyway no good crying £88.00 compared with a duff transmission is peanuts so I bought the stuff and commenced the operation.
I was going to do the flush as described on Lexls but then decided to do the sump pan drain and refill method therefore draining around 2 litres then refilling repeatedly.
Up on the axle stands and armed with a 14mm ring and a suitable drain container I released then removed the bolt.
As the old oil stream came out it did look a nice cherry red which at this point made me think "has this been done before I bought the car" ( being an import I had no service history dispite making many enquiries).
However once I had poured it into an old plastic pop bottle to measure it accurately I was convinced that it was original as it was nearly black in color!
I think left much longer I would have had serious problems.
So if anyone is "thinking" about this job DO IT! I was lucky to get away with mine but it does show the tolerance of the Lexus transmission to put up with old fluid in this state.
I had no noticeable problems with the transmission with the fluid in this state it was still as smooth as silk.
Just so you can gasp below is a picture showing the difference.
Steve...does your wife know you used her good measuring cup??! :o
She found out I had been using it , I am now called Steve Austin the Six Million Dollar Man.........Barely Alive :lol:
lol, we'll be taking up donations for you!!! :lol:
Ah, I did gasp. :) Did it appear clean on the dipstick, or not that noticably dirty until it was in the container?
I have looked at mine on the stick and it appears to be light pink in color... should be OK for awhile.
LOL! :D
On the dipstick it did appear reddish brown but to see the true color wipe the dipstick on a piece of white kitchen paper towel.
