RufioRiceDragon Posted November 7, 2009 Share Posted November 7, 2009 When the car is in park or neutral it will idle and the engine will rev properly. In reverse, drive, 2, and L, the rpm drops below 1k and hitting the gas wont get it to rev properly anymore. the car has been sitting for a couple weeks. I just changed the oil, oil filter, air filter, knock sensor, radiator, and added transmission fluid. The car recently overheated and the cylinder head had to be re-manufactured. Quote Link to comment Share on other sites More sharing options...
era57 Posted November 15, 2009 Share Posted November 15, 2009 When the car is in park or neutral it will idle and the engine will rev properly. In reverse, drive, 2, and L, the rpm drops below 1k and hitting the gas wont get it to rev properly anymore. the car has been sitting for a couple weeks. I just changed the oil, oil filter, air filter, knock sensor, radiator, and added transmission fluid.The car recently overheated and the cylinder head had to be re-manufactured. This is just a guess, but have you checked the accelerator sensor? My 99 gs400 needed a replacement recently. At times the rpm would remain at about 1 and the gas pedal wouldn't respond. Good luck! Quote Link to comment Share on other sites More sharing options...
