The Dunk Posted October 27, 2009 Share Posted October 27, 2009 Can anyone give me some help on how to change front light bulbs? My front low beam is out and I need some advice on how to change bulb - any help would be greatly appreciated. Thanks in advance Quote Link to comment Share on other sites More sharing options...
billydpowell Posted October 27, 2009 Share Posted October 27, 2009 Can anyone give me some help on how to change front light bulbs? My front low beam is out and I need some advice on how to change bulb - any help would be greatly appreciated. Thanks in advance remove the screw that holds the outside light and pull it out forward (hard) then remove the 3 bolts holding the headlight in.... 2 in front and one on the side. thats it. shouldnt be a problem.. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted October 27, 2009 Share Posted October 27, 2009 This should help you http://www.toyodiy.com/parts/p_U_1996_LEXU...EPGKA_8101.html Quote Link to comment Share on other sites More sharing options...
dashan Posted October 28, 2009 Share Posted October 28, 2009 I just removed and replaced the low beam headlight bulb of the driver side of my 96 LS. 1. Remove the battery. 2. remove the half-plastic ring on the back of the low bean head light. 3. release a spring wire that keep the light bulb in place. 4. pull back and retreat the head light bulb socket. 5. Remove the head light bulb. 6. Put the new head light bulb in. It is a little tricky, it will take you a few minutes to figure it out. YOu don't need to remove the head light lamp. This should help youhttp://www.toyodiy.com/parts/p_U_1996_LEXU...EPGKA_8101.html Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted October 29, 2009 Share Posted October 29, 2009 There is no reason to remove the lamp housings or battery and everything to just replace the normal HI/LOW headlamp. all you need to remove is the intake piping far enough to get to the passenger side bulb. Unplug... remove top half of plastic surround.. pull back rubber... replace bulb... Quote Link to comment Share on other sites More sharing options...
