Windshield Water Pump
sampaula
my wipers are working. Windshield water pump does not work I have water in the tank but do here the motor run when I push the washer spray button in the car. I need to locate the pump and change it can someone help with picture to located this pump.
There is a diagram here: http://www.toyodiy.com/parts/p_U_1992_LEXU...EPGKA_8503.html
If you you can hear your washer pump running, maybe a hose is clogged.
On most Toyota/Lexus vehicles, access to the washer pump is by peeling away the forward part of the liner in the wheel well -- may sound difficult but one of my a bro-in-laws recently did exactly that to replace the washer pump on his Camry in just a few minutes.
on my old 95, I had to remove the liner to get to it, more than a few minutes.... camry is not quite like a 400.
