Rear Bumper "top Plate" Replacement
v4tuna
I am looking to replace the black plastic sill plate on the rear bumper. You know the piece that says Lexus on th e top of the rear bumper
Mine is cracked but the bumper is fine Anybody know if /where i can replace it?
Yep, I think it is just held on with double sided tape.
http://irontoad.com/Merchant2/merchant.mvc...;Store_Code=LSC
It's held in place with a super duty double-sided tape. You should be able to pull it off - perhaps in pieces - with a little effort. A solvent like Goof Off (Goop Off?) should help remove the tape/adhesive from the bumper. The replacement kit is available from your friendly Lexus parts department.
