Replaced Iac, Mass Air Flow & Ecm & Still Not Fixed
beaudroix
My 94 LS400 hesitates, almost shuts down and the engine light comes on when trying to accelarate over 2000 rpm's. The Toyota dealership first said the car was throwing codes for the Throttle Positioning Sensor, they replaced, car worked fine for one day then problem came back but the TPS codes went away. Then the codes for the IAC valve and the Mass Air Flow came up so Toyota relaced them, car worked for one day them problem came back but both codes went away. Finally Toyota said the ECM (car's computer) needed to be replaced because it was throwing wrong codes. I could not afford the Lexus ECM ($1,400) so I had Toyota remove the ECM, sent it to Auto & Truck Electronics (they specialize in rebuilding these ECM's), they rebuilt it, Toyota put it back in and again did fine for one day and started the problem again. I am begging for an answer here! Someone please help...
give exact codes,dont just say the iac code or tps code, reset ur ecu by taking out the efi fuse under the hood then drive it till the light comes on then retrieve the code(s)
I disconnected the battery, nothing changed, problem still exists. Where can I find instructions on how to check codes?
I had similar problem with my 91 LS400 and after over two months of infrequent troubleshooting and headache, I changed the fuel pump and fuel pressure regulator and the problem was solved. Check the fuel delivery pressure with a gauge and see if you are having a fuel starvation problem. Good luck.
