stroker Posted September 2, 2009 Posted September 2, 2009 On my 91LS I have noticed there are 2 hoses coming up from the pump, one is attached to the intake manifold and the other is not connected but is plugged. I have noticed some white smoke from time to time from the exhaust and wonder if the PS fluid is being sucked in through the intake and out the exhaust. I have added about an ounce or two a couple of times of fluid but cannot see any fluid anywhere leaking. Any thoughts are appreciated. Thanks, B
93ls400walt Posted September 3, 2009 Posted September 3, 2009 these hoses connect to an idle up valve that works to increase rpm a bit during turning the wheels. the valve is known to leak and suck p/s fluid in and therefore into the intake, causing smoke. if i remember right from older threads the smoke tends to be blue. Try a search there had been a few threads on this issue
eatingupblacktop Posted September 3, 2009 Posted September 3, 2009 Here's one you can can start with: http://us.lexusownersclub.com/forums/index...?showtopic=6583
jpourcy Posted September 3, 2009 Posted September 3, 2009 Hi Stroker, The number to the part you need is 17630-16040 and it lists for 87.75 at the Lexus dealership. (That is either the list price or my price I can't remember which. I buy stuff through the shop I work at.) I haven't changed mine yet but I will be doing so in the next few weeks. I read that you can change it in about 10-15 minutes if you go from the bottom of your vehicle. Mine blows the smoke, kind of white and blue mixed and sucks power steering fluid. I have to add fluid about once every week to week and a half. I'm looking forward to getting mine fixed. I heard some people just block theirs off and claim it still works OK, but I would rather go back original. Jerry
eatingupblacktop Posted September 3, 2009 Posted September 3, 2009 Hi Stroker,I heard some people just block theirs off and claim it still works OK, but I would rather go back original. Jerry If you block off the line to the intake, you lose the idle up for parking maneuvers. Stick with the original design.
