Jeffstpetebeach Posted August 19, 2009 Posted August 19, 2009 Hello, I have a question to ask. I pull out the front oxygen sensor and it has Denso part # 480467-48010, than I pull out the next one and it has Denso Part # 89467-48011, Are these two different Parts I thought the two manifold oxygen sensors were the same part. Lexus # 234-9009. By the way 1999 RX300. Thanks for your help on this. Thanks Jeff :D
blueridge Posted August 19, 2009 Posted August 19, 2009 Hello,I have a question to ask. I pull out the front oxygen sensor and it has Denso part # 480467-48010, than I pull out the next one and it has Denso Part # 89467-48011, Are these two different Parts I thought the two manifold oxygen sensors were the same part. Lexus # 234-9009. By the way 1999 RX300. Thanks for your help on this. Thanks Jeff :D Supposed to be the same: Toyota part 89467-48011 Denso part 234-9009. The one downstream from the CAT is the different one.
Jeffstpetebeach Posted August 19, 2009 Author Posted August 19, 2009 Hello,I have a question to ask. I pull out the front oxygen sensor and it has Denso part # 480467-48010, than I pull out the next one and it has Denso Part # 89467-48011, Are these two different Parts I thought the two manifold oxygen sensors were the same part. Lexus # 234-9009. By the way 1999 RX300. Thanks for your help on this. Thanks Jeff :D Supposed to be the same: Toyota part 89467-48011 Denso part 234-9009. The one downstream from the CAT is the different one. Thank you Blueridge Thats way I cracked the manifold, the wrong part was in there. I pulled the bottom one and that one was the one with part # 89467-48011. The sensor just didnt want to move Top one. thanks for your time
code58 Posted August 20, 2009 Posted August 20, 2009 Hello,I have a question to ask. I pull out the front oxygen sensor and it has Denso part # 480467-48010, than I pull out the next one and it has Denso Part # 89467-48011, Are these two different Parts I thought the two manifold oxygen sensors were the same part. Lexus # 234-9009. By the way 1999 RX300. Thanks for your help on this. Thanks Jeff :D Jeff- the 10 was the original A/F ratio sensor the cars were built with and the 11 is the replacement. Don't know that there's any difference between 'em, they just changed the # 1 digit. The 234-9009 is the same sensor with the Denso # because the other #'s belong to Toyota. Even the OX sensor (the 1 back by the Cat. Conv.) has the same threads, it just screws into the plate that bolts onto the pipe. What Blueridge meant is the downstream one is different in that it is an Oxygen sensor and the front ones are A/F ratio sensors.
artbuc Posted August 20, 2009 Posted August 20, 2009 Hello,I have a question to ask. I pull out the front oxygen sensor and it has Denso part # 480467-48010, than I pull out the next one and it has Denso Part # 89467-48011, Are these two different Parts I thought the two manifold oxygen sensors were the same part. Lexus # 234-9009. By the way 1999 RX300. Thanks for your help on this. Thanks Jeff :D Jeff- the 10 was the original A/F ratio sensor the cars were built with and the 11 is the replacement. Don't know that there's any difference between 'em, they just changed the # 1 digit. The 234-9009 is the same sensor with the Denso # because the other #'s belong to Toyota. Even the OX sensor (the 1 back by the Cat. Conv.) has the same threads, it just screws into the plate that bolts onto the pipe. What Blueridge meant is the downstream one is different in that it is an Oxygen sensor and the front ones are A/F ratio sensors. Originally, the wiring harness length was different.
code58 Posted August 21, 2009 Posted August 21, 2009 Originally, the wiring harness length was different. Thanks for reminding me of that Art.
